2 screws on rear rotor...
    i cant remove the 2 screws holding the rotor... i tried everything, hitin it with a hammer and turning it with a screwdriver at the same time, tried heating up the screw, nd i tried wd40.. nothing worked
    any advice
    drill out the head of it, so you can get the rotor off. then use vice grips to remove the stud that remains... if your new rotors didnt come with new screws, put in an order ASAP for a few new ones from the dealership so youll have them in time for the reinstall.
      You don't really need those screws. The torque from the lugnuts should hold the rotor to the hub just fine.
      Gary A.K.A. Carter
      [sig killed by photobucket]
        i wouldn't have used heat, try dry ice... it shrinks the metal allowing for space to turn. trust me it works. either way... good luck.
        1992 Accord EX MT : CB#2
        DIY OEM amber corners w/reflectors
          those are all good ideas but i think im goin to take the g mans idea
            i like the dry ice idea. i havent heard or seen that one yet. let us know how it works. alot of friends say drown each screw in wd-40 or pb blaster for 24-48 hours applying more when u think about it haha GL ill be doing this soon
            [COLOR="Magenta"]
              do what g-man said, then buy yourself the screws later.
                they sell a impact driver set just for those screws. the set is not expensive at all just buy that and take it off. useing a hammer and a screwdriver wont work you have to have a impact driver set to do it right.
                the lugnuts might hold it on good but i have seen lug nuts get lose and if that happens it wont be good i would put the screws back in dont do your brake system half ass.
                life is as good as you make it. So forget what people say and do what makes you happy
                  Thoes screws just hold the rotor on the car when its at the factory so they dont fall off... You dont need them really the wheel holds the rotor on not the little cheap screws.
                    thats what i thought cus those screws are small.. yea so 2morow ill prolly just drill the head off and put the rotor without them screws..
                    thanks guys for all the reply's
                      Lol, I used an air hammer to turn my screws out. They were extremely rusted on.
                      R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
                        cool go for it
