ugh bolt stuck and rounded off...
    those two bolts that hold that caliper part which is on the back of the rotor are rounded off... its a tight space and i cant drill out the head...
    once again does anybody have and advice
    Hammer a smaller socket on there. You'll be sacrificing the socket, and the bolt will need to be replaced (that's true no matter what...), but it should get it off.
      is this on your rear calipers? cause i have the same problem lol. i geuss i will try your method deeve
      You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
      Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
        This may sound stupid but if you can get in there with a grinder at all you can reshape the head enough to get it with the socket approach deev mentioned.
          That's true... it's more work, but if you can effectively turn it into a smaller size head to be used with a smaller socket, you won't waste a socket (and it may end up being more effective)
          Just one thing... NEVER use a 12 point socket on a 6 point nut or bolt! Always use the correct size and shape for what you're removing, always make sure your tool is on there securely, and make sure that the socket/wrench isn't already damaged.
            trying using a one size smaller socket, probably going to get worse, what i would do is use a flat chisel n a hammer, and make sure your hit it towards the left, n that will start to loosen it up, then grab a pair of vise grips n take them off.... it should work, WORST CASE, they have to get touched off.
            FreshNoz
              Just used one size smaller
              92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
              91 cb9 wagon
                You can buy these.
                http://www.sears.com/shc/s/p_10153_1...+extractor+set
                saved my ass on numerous occasions. they are worth every penny.
                Click to see ride.↓↓
                  Gee, thanks for giving the same advice you just read somebody else had already given him. I can tell you are going to be a real help around here.
                  OP, first of all, I'd try to soak it in some penetrating oil. Then, the grinding idea sounds like a good idea, but heres the way I'd go about doing it. Take a file, and start filing it down to give it some shape again, maybe file it down to about one size smaller. Then, instead of hammering a socket on, and risking damaging the socket, or possibly breaking the drive on your ratchet you'd be using (I've done it before), hammer on the circular end (not sure what it's called exactly) of a combination wrench onto the bolt. Use a 6 point as deev suggested. It should be fairly easy to get this end of the wrench on. Then, using a rubber mallet, I'd wack the wrench, or use another wrench or something to get extra leverage, and try to get the thing loose. It sounds really complicated, lol, but if you understand what I'm trying to explain to you, you'll find it shouldn't be too hard.
                  Man, if you lived closer to me I'd come over and help you. Lol.
                  R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
                    Kevin... please let the staff enforce the rules. When another member does it, it can be construed as flaming, and I'd rather not have to ban you.
                    He has been notified, and his post count has not increased since that notification. If it continues, he will be banned.
                      NEW PSN
                      H22wagon
                      New project. 95 EG HB H22
                      RIP
                        Originally posted by project93 View Post
                        You can buy these.
                        I have these and they've saved me several times as well.
                          Sorry deev, this guys useless posts have just been bothering me lately. He seems to do it in almost every thread. Once again I am sorry man, I'll try to tone it down a bit.
                            I understand... believe me! But I'm on it.
                            When someone like that appears, and flaming is allowed... it becomes open hunting season on postwhores... and it makes things difficult for the mods. People get banned, and we then have to put up with the angry emails (and the "contact us" link goes to me... )
                              Lol, I gotcha deev. Not a problem.
