mph gauge going crazy!!! HELP
    ive been haveing the wierdist problem and i have no idea what it is... when im on the road ramdomly my mph needle jumps from 50 to 80 to 120 jjust gose crazy but the car runs fine then after like a min, the lights on the cluster d4 the little green square begines to blink nd keeps blinking untill i turn off the car but the car drives fine no wierd shiftng some one told me that the reason that the d4 light blinks is cause something wrong with the tranny =/ am i going to have buy a new tranny? what could be causeing this issue.. btw i changed the tranny fluid cause i thaught that was the issue but its not..
    Seems as if you'll need a new VSS (Vehicle Speed Sensor) .. do a search, you'll find the topics.
    They can be had inexpensively from eBay ..
    Tomi
    My CB9/Wagon Thread Start to Finish:
    http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
      yea check the vss connection or the vss itself.
      COUPE K24
        vvs?? can that be found nd replaced on the engine bay or in like the tranny?
          It's in the engine bay .. above (on) the tranny ..
          but like '93CB7Ex said .. check the connections first .. it may be faulty .. it happens ..
          But more then likely, it'll need to be replaced ..
          Tomi
            here is a pic of it http://stores.channeladvisor.com/epa...?itemid=329107 i do not know where it is ..i`m guessing it`s on the out side of the trans
              ohh cool i just found it on ebay for a good pricee. think its simple to replace once its located?. think ima see if i can mess with it tommarow see if its faulty or loose. nd i think thats y my car is idoling wierd too cause i know its not my idle controle sensor. this little sensor causes some wierd problems.. thaught i needed a new tranny or something.
                can i replace it with out takeing off anything to get to it??
                  Yes. Although I found your grammar a little confusing to decipher, I think I get it
                  There are two. Your interest is with the countershaft speed sensor.
                  It is on the RIGHT hand side of the transmission. You'll see it sitting there near the rear trans. mount. Remove it's 6mm bolts, remove the sensor itself, and replace. Remember to also replace the o-ring before re-installing the new sensor. Make sure it seats well and proper too.
                  life is good.
                    no such thing as a countershaft speed sensor on a cb7. the VSS gear rides on the differential.
                    youll see the sensor if you look directly below the throttle body.
                    alot of times the connector itself is faulty. I would take the plug off and inspect the terminals for any corrosion or problems with the connection first.
                    member ride thread
                    DIVULGE MOTORSPORTS
