F22b dohc stock redline?
    Hi guys I've been looking around the forums here on CB7, to try and answer this question, but I haven't really found a common answer. So what does the f22b dohc redline at from the factory? I would like to know so I can get a P06 ecu tuned for the f22b dohc engine I recently purchased. Thanks for your help.
    same as a h23 i believe, sorry im not help
      Im assuming itll be a little higher due to its lower displacement than a H23.
      www.PreludePower.com
      BB SQUAD MEMBER #28 V.2
        peak power is at 6000 rpm, so redline is probably around 6.3-6.5k.
        96 mx-6, needs work...
        91 accord lx sedan, needs work...
          I think he wants to know the rev...limit?
          Its safe to put it at 6700, same as the F22A (Same crank?)
          Your man for wiring solutions!
          CB7Man's Coupe H22 Swap
          CB7Man's Sedan Resurrected From The Dead
            yeah x2 also you lose power fast after 6000
              6700-6800 sounds good!
              MRT H22A - 302whp - N2O
              MRT F22B - 643whp - 529tq @ 30psi
              11.33 @ 131mph @ 27psi
                So you guys think its the same redline as the F22a, which is 6700.
                  i would honestly just set it a 6500rpm. that way you know your in the clear.
                  Click to see ride.↓↓
                    It has a rotating assembly virtually identical to the F22A, the only real difference is the head. So the rev limit from the factory is the same as the F22A. It has the potential to rev to about 7000 RPM though, because it's a dual cam and that kind of changes things up a bit. I'd just set it at the same as the F22A, considering it's peak power band is at 6000 RPM. If you put some performance camshafts in it however, you should raise it a little, considering a more aggressive camshaft will raise the powerband. Just my thoughts.
                    R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
                      F18A
                      Bore × Stroke: 85.0 × 81.0 mm
                      Displacement: 1849 cc
                      Valve Configuration: SOHC, 16 valves
                      118 bhp up to 1997
                      105PS @ 6000 rpm, 14.6 kg m @ 4000 rpm (PGM-carb)
                      Fuel consumption : 13.0 km/l
                      [edit] F18B
                      This engine was used for the Honda Accord 1.8 VTS/VTE in Japan. Also found in the European Honda Accord Vtec S.
                      Specifications
                      Valve Configuration: SOHC, 16 valves, VTEC
                      Compression ratio: 9.3:1
                      Max power: 138PS (103 kW)
                      Max torque: 124 ft·lbf (165 N m)
                      [edit] F20A
                      This engine series was used in the Honda Accords and Prelude`s in Japan and Europe. The DOHC F20A was also derived from this engine (see below).
                      Specifications
                      Bore × Stroke: 85.0 × 88.0 mm
                      Displacement: 1997 cc
                      Compression ratio : 9.5:1
                      Max output : F20A2 / F20A8 110 PS @ 6000 rpm (PGM-carb)
                      Max output : F20A4 133 PS @ 5400 rpm (PGM-Fi)
                      Max output : F20A5 150 Ps @ 5400 rpm (PGM-Fi)
                      Max output : F20A7 135 PS @ 5600 rpm (PGM-Fi)
                      Max torque : F20A2 / F20A4 / F20A8 18.5 kg m @ 4300 rpm (PGM-Fi), 16.1 kg m @ 3800 rpm (PGM-carb)
                      Max torque : F20A7 19.3 kg m @ 4400 rpm (PGM-Fi)
                      Fuel consumption (Japan Combined Cycle) : 9.6 km/l (PGM-Fi), 9.8 km/l (PGM-carb)
                      This engine also spawned many variants, according to market, but the specs remain largely similar, The F20A5 it's used in the Cb3 and Cb4 Chassis
                      The F20A7 is only used in the european "Accord Coupé 92-93" CC1 chassis as unique motorisation.
                      [edit] F20B
                      Specifications
                      Configuration Valve: SOHC/DOHC, 16 valves, VTEC/Non-Vtec
                      This engine came in SOHC in vtec and non vtec, there is also a DOHC VTEC version of the engine, they all share the same engine code although they are very different.
                      The DOHC VTEC version comes with a blue powder coated valve cover as the H23A VTEC from the japanese accord sir-t. They're called BLUE TOP and are only from japan.
                      DOHC VTEC Manual Version:
                      197 HP @ 7200RPM
                      145 TQ @ 6600RPM
                      147.10 kw
                      11.0:1 CR
                      85mm bore
                      88mm stroke
                      23mm wrist pin
                      145.5mm rods (f20b rod length = 145.425)
                      1.65 r/s ratio
                      55mm mains like h22a4 block
                      rod journal has been offset ground on both sides to the size of a b-series rod journal.
                      [edit] F20Z
                      This engine series is similar to the F20A above, used in the Honda Accord in Asia and Europe.
                      Specifications
                      [edit] F22A
                      This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar.
                      Specifications
                      Bore × Stroke: 85.0 × 95.0 mm
                      Displacement: 2156 cc
                      Valve Configuration: SOHC, 16 valves, non-VTEC
                      Compression ratio: 8.8:1
                      Max power:
                      F22A1: 125 hp (93.21 4 kW) @ 5200 rpm. NOTE* The 1992-1996 Prelude S had a F22A1 but because of a different more aggressively tuned ECU (P12), the power output was 135 hp (101 kW).
                      F22A4: 130 hp (96.94 kW) @ 5200 rpm. The F22A4 is the same motor as the F22A1 but it has slightly more power due to a tubular designed header and slightly bigger exhaust piping.
                      F22A6: 140 hp (104.40 kW) @ 5600 rpm. The F22A6 is the same as the F22A1 except for a slightly more aggressive camshaft, a better flowing cast exhaust manifold, a different more aggressively tuned ECU (PT6), and a different intake manifold that utilizes IAB's and also has a bigger plenum. The F22A6 also has a windage tray in the oil pan, and stiffer valve springs to accommodate the more aggressive camshaft.
                      F22A7: 140 hp (104.40 kW) @ 5900 rpm (147 hp/108 kW with manual transmission)
                      Max torque:
                      F22A1: 137 ft·lbf (186 N m) @ 4000 rpm
                      F22A4: 142 ft·lbf (193 N m) @ 4000 rpm
                      F22A6: 142 ft·lbf (193 N m) @ 4500 rpm
                      F22A7: 145 ft·lbf (198 N m) @ 5000 rpm
                      [edit] F22B1
                      This engine was used in the Honda Accord EX and Acura CL 2.2. It was the first F engine to feature VTEC. This engine has a different head than the f22a6 (specifically exhaust manifold/header-pipe as well as intake gasket).
                      Specifications
                      Max power: 145 hp (108 kW) @ 5500 rpm
                      Max torque: 147 ft·lbf (199 N m) @ 4500 rpm
                      [edit] F22B2
                      This engine was used in the 1994-1997 Honda Accord DX, LX and SE. The F22B6 in the 1995-1997 Honda Odyssey and the F22B8 in the Honda Shuttle are substantially similar. Also the F22B3 engine used in the 1994-1997 Australian and New Zealand Honda Accord LXi are basically the same engine apart from slightly different intake and exhaust manifolds.
                      Specifications
                      Max power: 130 hp (97 kW) @ 5300 rpm
                      Max torque: 139 ft·lbf (188 N m) @ 4200 rpm
                      The F22B in the BA9 Prelude had a DOHC configuration
                      JDM engines were stamped only as F22B.
                      [edit] F22Z2
                      This engine was used in the Honda Accord 2.2i.
                      Specifications
                      Max power: 150 hp (112 kW) @ 5500 rpm
                      Max torque: 148 ft·lbf (200 Nm) @ 4500 rpm
                      [edit] F23A1
                      This engine was used in the 1998-2002 Honda Accord LX, EX, and SE, and in the Acura 2.3CL in North America.
                      Specifications
                      Bore × Stroke: 86.0 × 97.0 mm
                      Displacement: 2254 cc
                      Max power: 150 hp (112 kW) @ 5700 rpm
                      Max torque: 152 ft·lbf (205 N m) @ 4900 rpm
                      [edit] F23A4
                      This engine was used in the 1998-2002 Honda Accord ULEV models. It is substantially similar to the F23A1, but features ULEV certification with a slight reduction of power: 148 hp (108 kW) with a maximum torque of 150 ft·lbf (203 Nm). This engine has a different exhaust manifold and a 32-bit ECU which uses a wideband oxygen sensor.
                      [edit] F23A5
                      This engine was used in the 1998-2002 Honda Accord DX and the 2002 Honda Accord LX VP (value package) in North America.
                      Specifications
                      Max power: 135 hp (100 kW) @ 5500 rpm
                      Max torque: 153 ft·lbf (206 Nm) @ 4500 rpm
                      [edit] F23A7
                      This engine was substantially similar to the F23A1. It was used in the 1998 Honda Odyssey and the 1998-1999 Isuzu Oasis.
                      [edit] DOHC engines
                      [edit] F20A
                      This engine was used in the 1990-1993 CB3 and CB4Honda Accord 2.0Si and Si-T in Japan.
                      Specifications
                      Valve Configuration: DOHC, 16 valves
                      Compression ratio: 9.5:1
                      Max power: 150 hp (112 kW) @ 6100 rpm
                      Max torque: 137 ft·lbf (186 Nm) @ 5000 rpm
                      [edit] F20B
                      This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from Japan. It uses a DOHC VTEC cylinder head similar to the H22A found in the Prelude but was designed to comply with many countries' sub-2.0 liter tax. The automatic transmission versions received the lower hp version (180 hp), as it was tuned for more mid-range torque than its manual transmission counterpart.
                      Specifications
                      Accord SiR wagon, SiR-T F20B 97-01 2.0L
                      Valve train: 4 Cylinder, DOHC VTEC, 16 Valve
                      Bore: 85.0 mm
                      Stroke: 88.0 mm
                      Torque: 145 ft·lbf (197 N·m) @ 5500 rpm
                      Horsepower: 200 hp (150 kW) @ 7000 rpm
                      Red Line: 8200 rpm
                      Compression: 11.0:1
                      Fuel Control: OBD-2
                      [edit] F20C
                      Main article: Honda F20C engine
                      This engine was a radical departure from previous F engines, and only shared basic dimensions such as bore spacing. It was designed specifically for the Honda S2000 and shares some engineering with the Honda K engine. A long-stroke F22C1 variant was also produced.
                      [edit] F22B
                      This engine was used in the 1992-1996 Honda Prelude Si in Japan. It is similar to the H23A
                      Specifications
                      2.2L
                      Max power: 166 hp (119 kW) @ 6000 rpm
                      Max torque: 150 ft·lbf (200 N m) @ 5000 rpm
                        Old but answered... My p39 hits fuel cutoff at 7100.
