A/C not working!!! HELP!!
    Hey guys my a/c went out on me a few weeks ago. I know the compressor is coming on. (I can hear it) And it is not the control panel. The temperature knobs do work. I first realized it stopped working when it rained HARD on my way back from Denver. The front windshield fogged up so bad that I had to pull over. Then I realized it wasn't getting cold AT ALL. No warning. The system is charged completely. No leaks.
    Any input would be greatly appreciated.
    take it out lol ....or check your condensor fuses
    Team Accord #17 F & H series or no series....Rota Slips are the new steelies -_-
      I think I figured it out. The a/c clutch isn't fully engaging. Do you guys think I should just replace the clutch or the whole compressor?
        Depends on how old the compressor is and what the delta is on buying the two parts. My guess is you would be better off replacing the whole compressor since odds are that your compressor is old and could go out later, not to mention the price is probably close between just getting the clutch and getting the ac comp with a clutch.
          Are you sure it's fully charged? I had an issue once where I thought it was charged but instead it was full of air. I had a shop recharge it with oils and it fixed my problem.
          http://www.FLAccords.com
            if youre gonna open the system to change anything, you might as well do the r134a conversion while youre at it , because every time you open your system , or it springs a leak its gonna dump all that r12 outta there, and that shiz aint cheap.
              Hey guys sorry for not responding sooner. It think the problem was my a/c clutch. I priced a new one but decided to go to a U-Pull It. ( I know I am cheap) I got an entire compressor for like $20.
