cluster question
    cluster question
    What other clusters work in a 90-91 ex 4 door with no cutting wire mods?legend? prelude? please lmk because all the junkyards over here have Lxi's and then 92-93 cb7s =/ and im in need of a cluster badd
    Team Accord #17 F & H series or no series....Rota Slips are the new steelies -_-
    stil no answers?
      you could use a 92 or 93 cb cluster but i kno the prelude and legend cluster u have to do some wire cutting
        na i cant use the 92-93 cluster because the pigtails are different
          who told u that a 92-93 cluster would work?
            You will need a 90-91 cluster, but a 92-93 cluster will work too. However the component of the 92-93 will right signal light will be on when you have your e-brake on I think. I try this before, so my suggestion is to get the 90-91 cluster. If you can not find one at the junkyard, you should go to Autozone.
              my homeboy tryed it before thats how i kno
                he musta did somethin because on the left side the pigtails(prongs) are wider than the 92-93 cluster
                  Yea, the 90-91 cluster connections don't match up to the 92-93 cluster. You would have to change the harness.
                  Ground Up Construction In Progress
                  Members Ride Thread
                    and im not the person to cut wires lol
                      you dont have to worry about a cluster now cuz u have 1 now
                        so what did you end up doing? stock or did you fab something sweet in?
                          I ended up swapping the temp guage with the 90-91 cluster that i got from 92accordkid with a 92-93 temp guage and drained the gas and reset the needle and ecu andd my gas guage is back to normal lol... ...nothing really fancy i painted the trim gold to goo along with my carr
