Car is about to be started for sitting nearly
    4 months and i wanted to know what things should i change or stuff?
    i would def check all the belts and plugs. Put some dry gas in it and run it awhile. If the car wasnt moved at all and wasnt on jacks i would check the tires also....all the fluids..basically make a checklist and go down it.
      yeah it was on jacks so tires are in decent like what fluids should i check??
        Just change motor oil, do a prestone test and it wouldn't hurt to change the tranny oil while you're at it.
          well when i take my car out of storage i change all the fluids..tranny/oil/radiator/brake.
          Basically everything..unless i drove the car alittle over the winter..just to get the fluids moving is the key part. If its been turned off and not moving for 4 months then i would do all this.
