Stock motor... it cranks, does not start at all! I took the the wire off and put a plug to it no spark. I have 12 volts at the distributer I took the cap off and tested it through the center of the cap. It was running ideling in the driveway when it shut off then wouldnt start again. 256k Should I just replace the distributer? is the coil and igniter in the dizzy? could I have broke the timing belt? main relay clicks and shuts off with engine light so I dont thinks its that.
No spark 92 cb7
check your fuses.. and doubt it was ur timing belt. for ur dizzy.. pull a spark plug out have it plugged in to the wire have the side base of the plug on a ground on ur car like a frame or something grounded to ur chassy. then have someone crank it see if ur getting spark you'll see it. just check lil shiz here and there shouldn't be hard to figure out whats going on..
Air/fuel/spark/compression....you are missing one. Time for a diagnosis. Just jump through the hoops accoding to the manual and you'll eventually find it. It's most definately not a broken timing belt....if so it wouldn't crank, it would be all starter.Last edited by 5sp5drCB; 02-10-2010, 11:53 AM.
ok good I will check again should I take the cap off and crank it to see if the rotor turns?Originally posted by 5sp5drCB View PostAir/fuel/spark/compression....you are missing one. Time for a diagnosis. Just jump through the hoops accoding to the manual and you'll eventually find it. It's most definately not a broken timing belt....if so it wouldn't crank, it would be all starter.
which fuse?Originally posted by jdmguy91 View Postcheck your fuses.. and doubt it was ur timing belt. for ur dizzy.. pull a spark plug out have it plugged in to the wire have the side base of the plug on a ground on ur car like a frame or something grounded to ur chassy. then have someone crank it see if ur getting spark you'll see it. just check lil shiz here and there shouldn't be hard to figure out whats going on..
exzactly it just cranks.Originally posted by konig52r View Postif it was the dizzy, the car would just crank. you would have no spark either. If it starts and then shuts off, it might be the alternator
check all your grounds also... i had this same problem with my 90 LX... ended up striping car because it needed a new wireharness... hope u get it running soon
Originally posted by deevergotewen yous in da import seen yo, u gotta tipe lyke yous from da streetz cuz it showz dat u git mad rezpect yo. toonerz dun tipe lyke dey gotz a edjakashun cuz dat aint coo.
