any info?
    any info?
    ok so i have a f22b dohc head that im about to put onto a f22a1 sohc block. is there any special tools i will need? im guessin power tools or air compressed right? i know the head gasket and fluids will need to be replaced. any maitenence info will be great thanks
    this has been gone over many times, please search.
    first off, why are you swapping to the f22b head? just because it has vtec? the f22b is a horrible head design compared to the f22ax which happens to be the best flowing head honda made until the s2000. vtec on sohc engines is worthless for performance, it was only designed to give better economy.
    secondly, when swapping heads, you will need new head bolts (bolts will stretch when they are tightened down, so they are significantly weaker than new ones.) i suggest ARP head studs, but they are not required. you will also need a head gasket (like you said), valve cover gasket set, spark plugs, a new timing belt, timing belt tensioner, and you might as well change out the water pump while you are messing with that stuff. it would also be a good time to change out all the seals in the head, particularly the cam seals.
    as for tools, you will need a 14mm and 10mm socket, an extension at least 4-6 inches long, ratchet, a breaker bar (for getting the old head bolts out), and a torque wrench.
    dont just slap some random head on there either. it is always best to at least have the head and block inspected by a machinist to see if they are warped or scratched. you will likely end up having to have the block and head decked just a little bit to clean it up and make them each perfectly flat.
      well its a non vtec head its the jdm dohc. i blew the block out and had a machinist look already and the head is fine by a miracle. thanks for the tool info but is the swap still pointless?
        The swap is pretty straightforward. I'm not positive on the piston design of the F22B, but you may end up with slightly lower compression. Other than that, it should bolt directly on. The blocks are very similar.
        Definitely have the head and block inspected, and make sure that they're completely flat.
        Don't use power tools. Use proper hand tools, and be sure your torque specs are correct. Also, pay close attention to the tightening pattern.
            ok thanks deevergote, im from southeast texas and the weather sucks right now, plus my car is about to be covered outside cause im about to help my friend drop a new H23 in his 92 prelude and it will take up my garage glad its a striaght drop in i will keep you posted on it though. might be a month or two before i start.
