What cause the engine to jump when shifting on D. I have a auto. It basically the car jump forward.
What cause engine....
The car jump forward when I shift to D while I press the brakes in deep, after that the car vibrate alot. No idle problem it just vibrate alot and noisy. It doesn't shake when I put it on P, R , N. It shake on d4,d3,d2,d1.Originally posted by Sarthos View PostBad parking brake? Or bad transmission could maybe do it? Does it do it when shifting out of Park if you shift to reverse? Does it do it if you shift from neutral to reverse? Does it do it when you shift from neutral to drive? Does it shift if you shift it from low to second to d3 to d4?
