driver side window wont go up!!!!
    all other windows go up and down jus fine. all the fuses are good.
    driver side window went down and started going up and stopped and hasnt worked since. could it be the motor going out?
    F22B Swapped CB7
    It started going up you say. Could it go back down after that? My passenger window couldnt go back up via the driver switch. The passenger switch worked though. I swapped out master window switches and it was up and running. Same thing happend with my brothers coupe it was the master switch.
    If your motor went out it would have been going slow and working like crap leading up to the failure
      it was moving just fine then it just cut out
      F22B Swapped CB7
        found the problem, changed the master switch and that wasnt it so i started playn with the wires. one of the wires running inside of the door has a short and i had to bend it to get the window to go
        F22B Swapped CB7
