Hey guys i figured i should just post up and ask here, i have a h22 swapped in with a h23 tranny, (i didnt do the swap) and the tranny right now grinds, so i got a new h23 tranny but i dont wanna pay a mech to do it for me and im trying to learn how to get into this anyway, i tried searching the forums but i couldnt find anything that was that detailed. the h23 tranny i bought is already tapped for the accord mounts. Can someone give me a detailed guide on how to swap the trannies out preferably without dropping the engine out? And i wanted to do the clutch and flywheel out of the current transmission into that new one too.
Swapping a Transmission
The clutch and flywheel will be attached to the engine. Just leave them in place.
Your best bet is to get a manual (there are some that you can download at the top of this section). It would be quite involved for someone to type out all that needs to be done.
Essentially, you need to drain your transmission.
remove the axles (both axle nuts, and separate both lower ball joints... this can be tricky. if you tear a boot, it's best to just replace the ball joint... separate an axle, replace the axle)
Remove the intermediate shaft on the back of the engine.
Unbolt your clutch slave cylinder and move it out of the way. Don't detach the lines, or you'll have to re-bleed the system.
Remove your starter.
Remove your distributor (carefully mark where it was, or be ready with a timing light to adjust the timing when you put it back)
Remove your front crossmember and radius rods.
Remove your battery and intake.
Support the engine from underneath with a padded jack
Lower the engine about an inch by the driver's side mount (this is necessary to get the transmission to clear the fenderwell)
Remove the transmission mount
Disconnect your VSS
Unbolt the transmission (while having someone support it, to be safe)
Keep track of all bolts you remove... you will need to know what goes where. They're not all the same.
Carefully remove the transmission. It's heavy, and awkward. All the weight is on the outside.
Position the new transmission, and work it into place. If the splines don't line up right away (they never have for me), you'll need someone to very slightly turn the crank via the crank pulley while you slide it into place.
Get it into place, get one bolt in there to ensure it's on... then begin re-installing everything you removed.
That is in no particular order, and I may have missed some things... but that's generally how you do it. Get a manual for diagrams and more details.
That is very true. If you're not lucky enough to get the transmission back on quickly, it can be difficult. I've had fairly strong friends helping me in the past, and even with them doing the heavy lifting (basically benchpressing that awkward thing), it can be difficult. Once the person lifting gets tired, it's a pain in the ass. I've never used a transmission jack, but that would've come in handy!
