Wiring Issues.....
    Wiring Issues.....
    wassup fellas im having some very annyoing WIRING issues.... it all started when i wired my high-beams(Yellow's) to be controlled by my Cruise Control switch..... ever since then my radio has lost power.... and now my Rad Fan just stays on for i dont know how long and goes off when it wants to the point where it drained my battery..... but for the most part i need help with my Radio issue.... does anyone know how to Hard-wire a radio....
    First off, why did you wire your high beams to the cruise control switch?
    And as for the radio, you can run the red wire to the radio fuse on the drivers side kick panel. The yellow wire, hook that to a fuse that has a constant 12v power source with the key off, then find a ground.
      [QUOTE=nine_deuce;2449154]First off, why did you wire your high beams to the cruise control switch?
      well i wanted to be diff and control my High Beams without any other lights being on but i dont think thats the problem.... because i have relays for that but..... thanks man imma try that with the hard-wire....
