Hey getting a h22a vtec head, solenoid, ecu, and harness and I'm wondering if it will bolt on to my f22a4 sohc motor? will i have to bore out the cylinder walls and all that will it even work with my motor? I know it works for an f23 but obviously i dont have that.
G22 swap?
I wouldn't consider it a "bad" idea, I'd consider it a "risky" idea. Most people try to do it the cheapest/easiest way, and end up blowing something up. If you have the time/dedication to research prior to the swap, and take your time with it, you'll be fine.Originally posted by Reignstarz View Postwaait so it's bad to get an h head on an f block?
Damn I really wanted vtec and wanted to keep my f block =[
Is there a certain reason you're wanting to keep the F-block? Unless you're getting a hell of a deal on the H22 head, just stick with your F22.
You'll have a low compression H22. It'll put down numbers close to non-VTEC H23 numbers.
Low compression and a motor that will rev safely to 1000 RPM lower than an H22.
It'd put out H23 horsepower if you're lucky... and considerably less torque.
If you want VTEC, get a full H22, or an F20B. VTEC is about optimizing airflow... and a low-compression, low-redline motor is NOT going to do that for you.
X2Originally posted by deevergote View PostNo, it makes an F/H hybrid engine. It does not make it a Ganything.
That's like saying "if I combine a Honda and a Toyota, I must get a Nissan!"
No.
I curse the dumb fuck that popularized the "G22" and "G23" shit.
Its like nobody has even heard of the ALREADY MADE ACTUAL G SERIES 5 cylinder engines honda made, would love to get one though... be a crazy build (expensive as hell with all custom stuff)
but enough that, as others stated it is not worth it. and im about 99% sure it WONT put down h23 numbers just because of that head. Power from the H22 comes from a different bore and stroke/ fuel mapping/ DOHC/ timing/ higher compression/ different intake and exhausts as well. theres more im sure obvioously, but understand putting the head on will do practically nothing, unless serious engine building will be taking place as well....Originally posted by deevergoteInstalling a turbo and planning to tune later is kinda like having sex and planning to put the condom on afterward.
yeah well i was originally gonna get the full h22 swap-h23 motor with h22 tranny and h22 vtec head-but then i heard about how this G22 swap is supposed to be much more faster and i did some research and figured i'd save money and put much more power out.
but wtf guess i'll just save the rest of my money and get that full swap
