Hey guys, I have a 93 accord EX (f22a6) and it has been throwing a code 43 as stated in the title. Sometimes it acts like it is starving for fuel, it cuts out and sputters, but if I go ahead and give it more fuel, it seems to clear out usually...Sometimes I have to turn the car off, the key back on to prime the pump and start it, does ok for a while...It is very inconsistant I can't seem to find any pattern to it to speak of.
I have cleaned the injectors and replaced the fuel filter. I also swapped out the MAF (dunno if its relevant, but i tried it) and it didnt help.
It has a new distributor, plugs, plug wires...
I was wondering if someone could point me in the right direction for troubleshooting this problem? Perhaps without dropping the tank, if possible. By that I mean, I'd like to eliminate the other possiblities before I fool with the fuel pump.
On a side note, after I start my car and take off, my abs motor makes a wierd buzzing/whirring sound for 5-6~ seconds and stops, then the ABS light comes on. Ideas? Is there any way to completely bypass the ABS?
Any and all help is much appreciated.
edit: i ran the most expensive STP fuel system cleaner i could find through it...they didnt have seafoam where i was at.
I have ran 2 tanks of 93 octane gas , non ethanol (woot) so I think that marks out bad gas /water
O2 sensor? ahh im freakin' out man! :P
