car shakes in between rpms
    Ok I got this problem wit my car? So when I start taking off I feel the car shake a lot in between 1500 all the way to 3000 rpms. I already checked the motor mounts there good and I checked the balancer shaft and its good anybody might kno wat it can be thanks for checking this out.
    did u check the tranny mount? sometimes those can make the car rattle aswell..
    My ride
    http://www.cb7tuner.com/vbb/showthread.php?t=154423
      I'd check plugs (gap/spark), wires, and timing next. Shitty spark on one cilinder can cause harmonic disbalance at some RPMs and not others. How does it idle?
        Maybe a really messed up inner cv joint on one or both sides. I've heard that if they are really worn or somehow damaged then they won't transfer power smoothly to the axle and outer cv joint and you will get vibrations.
          Idles fine once in a while it revs up and down for a lil the tranny mount is fine cv joints are new ill check the spark plugs and wire tomorrow thanks guys
            hmmm... if you just put new remanufactured axles on the car and this happened soon after then I would suspect a bad inner cv joint on one of them. Keep the possibility in mind but yeah go ahead and check the other things.
            don't forget the distributor cap if you're gonna check the plugs and wires.
            good luck
              Cool I'll check everything out k thanks a lot guys
                good luck
                That happened to me last week... I bought a re-furbished axle from advance and it was F..ing defective! I had to take everything apart all over again and exchange it for a new one..
                I was truly not a happpy camper..
                My ride
