Brake issue... help!
    Ok well i know that one of my calipers has been sticking. I have found out that it is the drivers side.
    I cleaned it up and tried to put it on with new pads only to find out it will not slide over the pads... im assuming because its stuck out??
    Is the big "piston" suppose to be sticking out at all with no foot on the brake??
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    First Brake Job
    Yes, the Brake Caliper Piston sticks out and must be pushed back. There is no mechanical advantage at the wheel, so you will have to use a tool to push the piston back. There are a variety of tools and methods that are acceptable, I would suggest a caliper tool.
    1997 Honda Accord EX-V6:
    Originally posted by James Matteu
    You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
      ok thanks... i got it pushed back and back on...
