So, I was driving my car today and began to smell burning rubber. I got out, checked under the hood, and didn't see anything unusual. The smell seems to be coming from the front tires area. Any ideas?
Burning Rubber Odor
Check your tire pressures- if you have a tire with little to no air in it, it can generate alot of heat before it will eventually fail.
Also check underneathe your car to see if anything rubber is stuck on the exhaust and burning up.ON_N20Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
Nope regular grandma drivingOriginally posted by fatboy1185 View PostBrake pads? Clutch? Where you driving aggressively?
It's an autoOriginally posted by JunyAccord View Postis it a standard? i cant really describe the smell of the clutch but its somewhat similar to burning "rubber".
Well my front 2 tires are bald. I doubt that could that be a cause though. I'll give it a look underneathOriginally posted by ON_N20 View PostCheck your tire pressures- if you have a tire with little to no air in it, it can generate alot of heat before it will eventually fail.
if ur fr0nt tires are bad then theres ur pr0blem.when tires get w0rn alm0st t0 the wire, that rubber thats left is extremly s0ft and smells even if u need an alignment.take a c0rner and it will smell.get them changed f0r 2 reas0ns.
1.cause the smell.
2. its n0t safe at all ur g0nna kill ur self.
