As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
FYI: Code 43 Fuel system supply
    Originally posted by wed3k View Post
    you'll probably have less than .01 ohm through the connector. remember to shrink tube it so no water gets in.
    Remember to put the wire through the shrink tube before you start, or soon you'll be unsoldering it to start over. Also, 4 short tubes for the individual wires followed by 1 longer jacket tube is best practice . Slide the big one on first.
    Also remember, solder is there to secure a good connection in place, not to make the connection.
      I cant find the O2 sensor on the site, any help? I have code 43 error as well.
        if you cant find it, it's probably under the car near the cat because ex's are back there.
          Oh well on the car yes I know that, but on the ROCKAUTO website. Im needing to get a new one, sorry I didnt make it clear the first time.
            Nevermind and wed3k, I'm probably going to just buy the sensor from auto zon (bosch). Due to the fact that I have other issues to fix and cant wait for shipment from other places. I will jack up the car, and probably get going on the replacement.
              Originally posted by vex View Post
              nevermind And Wed3k, I'm Probably Going To Just Buy The Sensor From Auto Zon (bosch). Due To The Fact That I Have Other Issues To Fix And Cant Wait For Shipment From Other Places. I Will Jack Up The Car, And Probably Get Going On The Replacement.
              Dont Buy Bosch!!
              2013 Ice Cream Cruise!
              VIDEO: 2012 Ice Cream Cruise
              VIDEO: 2012 Ice Cream Cruise part 2
              The single largest cruise in the Midwest!
              August 3 ~ Omaha, NE
              By 1320 Video
              Member's Ride Thread
                Originally posted by theSOB View Post
                Dont Buy Bosch!!
                It's all they have :S any other options? This will probably help my low gas milage and weird idling.
                  denso is hella cheap
                    bosch wont help anything
                    By 1320 Video
                      So then denso? Cmon I need some suggestions, you guys are just telling me whats bad and yelling random things.
                        Get Denso or NGK. I'm happy with my new Denso. If you did any kind of search on this site, you'd find this advice repeated endlessly.
                          Well thank for the recommendation and I thought since I pondered onto this thread i'd stick here and see if I'd get any help. But thanks again.
                            get a denso for a lower model accord like a dx or lx and just change the plug over. it will save you a couple bucks and if you do everything right it wont affect a thing.
                            i put a mustang 5.0 on my vw and saved 40 dollars. car passed smog like it was nothing.
                              after you replace the o2 sensor and it still has a code, you need to check the voltage and see what the voltage is. if it is still lean, see if it will go rich with carb clean or propane enrichment.
                              if it reads rich, make a lean condition like a large vacuum leak.
                                This thread was jacked and we're on page 2 now… better off editing the original post.
