wat could it be????
    wat could it be????
    so a few days back my accord started sounding like a tractor and would only stay on if it was floored . wats wrong with it ???? i changed the fuel filter it had never been replaced keep in mind the cb7 has 208,xxx miles could it be a bad injectors i dont wanna buy parts that are $$$$ taht i dont need . please help
    I assume that your check engine light is on... that will tell you what is malfunctioning. You just need to jump the service connector under the dash (to the right of the passenger footwell), turn the key to the II position, and count the flashes. There are detailed instructions and a breakdown of all the codes in the "sticky" threads in the regular Technical forum.
      First, start with the basics. Tune up items, such as spark plugs, plug wires, air filter, etc. Maintenance is key for any vehicle to survive. Judging on how the car has 208k on it and has never had the fuel filter changed(should be done every 30k or so) I'd say that would be a good place to start. Check your spark plugs, make sure they aren't gunked up, caked, or excessively worn. Check the distributor cap and rotor, make sure there isn't excessive buildup on the contact points on the inside or on the tab of the rotor. Make certain your plugwires function as intended, and doublecheck the ignition timing.
      If all of those are a bust, do a compression check and go from there.
      Also, if ANY check engine light or codes are present, RECTIFY THOSE FIRST!
      Hope that helps.
      -Jake
      '92 h22 CBMRT-->http://www.cb7tuner.com/vbb/showthread.php?t=158641
      UNICORNS=donkeys with plungers stuck to their faces...
        theres no engine light on and it has good fuel pressure i just checked it a has a good spark on the new spark plugs
          Does your check engine light come on briefly when you start the car? it should. Your bulb may have burned out.
            ya it will turn on and then will turn off like normal
              Ok, then anything associated with the CEL can be ruled out, most likely.
              Take h22cb719's advice, and we'll go from there. Even if those things don't fix the problem, they're good to do anyway.
                Exhaust manifold. My brothers cb7 sounds like a tractor with a rusted out exhaust manifold.
                  If it's really loud, that's definitely a possibility. A significant hole in the exhaust manifold could cause performance issues as well.
                    Other possibility is if the catalytic converter is clogged. I don't think that would throw a CEL.
                      It would probably result in the o2 sensor being ruined pretty quickly, which would result in a code... but if this is a fairly new issue, then that may not have happened yet. So the cat is certainly a possibility.
                      If you can take video of what your car is doing, that would be a great help.
                        thaNKS EVERONE FOR THE ADVICE BUT IT WAS PLUGED INJECTORS AND A BAD O2 NOW SHES RUNNIN CHERRY AGAIN
