Loose Clutch
    Loose Clutch
    My clutch feels really loose. Any way ya'll have tightened this up? Change fluid, adjustments, etc.? I recently had my clutch replaced. It was just a standard replacement. If I'd known about performance clutches, I probably would've installed something else, but that's past and I don't intend to take the engine out and replace it again at this point. So any suggestions any of you have will be appreciated. Feels like pushing a nail through soft butter when depressing the clutch. I'd rather have it feel like butter thats been out the fridge for about 10-15 minutes. But maybe this is the way a standard clutch on a 91 Accord EX feels.
    91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
    Neuspeed Super Cup Kit (7/2010)
    TAS rear drum-to-disc conversion (6/2010)
    Above photo taken - 4/2010
    Steel Braided Clutch Hose?
    How about a steel braided clutch hose? Anyone try this? Stiffer effect? Less travel?
      I have the steel braided line, but I nvr had the rubber line.
      I can tell you it works the same every time, I know where the clutch is going to be regardless.
      My Clutch engages right off the floor, it kinda sucks for racing, I grind gears sometimes if I dont have it buried in the floor
      Im running an OEM Exedy clutch kit and I too think the pedal is pretty pussy
      But you must remember its not the clutch that gives pedal resistance, its the pressure plate...OEM ones are very weak. They are for DD
      Now mix an OEM clutch with a better Pressure Plate, then youll get the pedal feel you want, with the longevity you want.
      Your man for wiring solutions!
      CB7Man's Coupe H22 Swap
      CB7Man's Sedan Resurrected From The Dead
        x2...i have the same feel in my stock clutch pedal...you need a stronger pressure plate...you can try bleeding the clutch line just in case you have some air in the system...but I don't think that will be your problem.
        "I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
        ASE Master Automotive Technician
        ASE Master Med/Heavy Truck Technician
        US Navy Electrician
        Contact me if you need help on the side.
        '92 Accord DX (For Sale)
        '01 Civic LX
        '00 Tahoe
        Greatest Rally Video Ever
