and f20a
    and f20a
    any one can tell me is that any vtec header can swap in my f20a block?????
    my motor is f20a sohc
    can any one help?????????
      Your posts are 25 minutes apart. It is a weekend day, and in the US (where the majority of the members here are from) the weather is quite nice. Chances are, people are NOT sitting home on cb7tuner.com. Relax!
      Header? Or head. They are different parts.
      The head is what has VTEC, so I assume that's what you meant.
      Yes, you can swap over the H22, F20B, or any of the SOHC VTEC F series heads. However, the SOHC heads are inferior to your non-VTEC head, and will offer no worthwhile performance gain whatsoever. The DOHC VTEC heads require some modification to get them to work. They are also made for high compression, high revving motors... which your F20A is not. Honestly, the gains are not worth the effort. If you want VTEC, get yourself a full H22 or F20B. Don't do a headswap.
        oooooo thanks for ur answer but if i get h22a full egine then can i use back my original wire????
          Some wires will have to be added, but that would be no different than if you used just the H22 head. Read the "sticky" threads in the Swaps section. There is one that shows the H22 swap in detail.
            ok thanks you alot
