Help PLEASE!!! Windows Wonnt Go Down
    Now, let me start off by saying. This is about my Volvo 940 wagon. If it's not cool to post this here, just tell me n ill delete cuz im not gettin any answers on the volvo forums. Anyways, i have a 1995 volvo 940 wagon while the CB's in the body shop. I hooked up my sub, sony xplod 1200 watt witta 300 watt amp, and now my windows wont roll down, my power locks dont work, and my power mirrors wont work. Any ideas why??
    Originally posted by scudweiser
    i farted while i was getting head once, i was drunk.
    I'm guessing it has something to do with the sub and amp drawing too much power from the battery, you need to buy something I believe. I think it's a bigger fuse, not sure though.
    Current:
    2007 Acura TL Type-S 6MT KBP
    Past:
    1992 Honda Accord EX-R Sedan - RIP
    1991 Honda Accord EX-R Wagon - RIP 10/14/2010
    Words change lives. You just got to choose the right ones.
    Instagram: @CB7Nub
    Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
      it could be that you didnt ground your amp correct..
      Check your battery at autozone or kragen and alternator too (its free)..
      if theyre good, then make sure everything else is good (ie fuses and grounds)
      take the amp out and check if it fixes the problem
      then if thats not it im all out of ideas...
      Rush
      Originally posted by Darkcloud
      Bought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
      Originally posted by bmxicansd
      so you got a boombox, sunglasses and rosettta stone?
        Get a test light and check for power coming out the main switch.
          have you check your fuses?
          JENNA 91 LX
          RIP 12-11-09 - 12/06/10
          JANE 99 Infiniti i30
          2-9-11 - current
          "Life is simple, you make choices and you don't look back."
            ^^ i'd check them fuses first. You could have grounded something out in the process of installing your stuff.
              the fuses are good. i disconnected amp and no luck. battery and alternator r brand new. could it be the relay? although, why would the locks and mirrors stop working if its just the window relay?
                anything?? i really need these windows, fucking hot during the day!
                  are you sure you checked all of your fuses? the problems you have are in series with something that could be a fuse. since it's more then one problem.
                  it could be the ignition switch going bad also.
                  Yes my name is Dang, Don't use in vain
                  1992 Honda Accord EX (Coupe/Bordeaux/Auto)
                  1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
                  2008 Honda Accord EXL (Coupe/SanMarino/6spd)
                    yep, every fuse that has something to do with the wondows and locks r good.
