bogs during hard turns
    93 SE 4dr auto. when i pull out left onto the road from my driveway the car bogs. I havent noticed it during right turns its definately during left turns. The car accelerates but very slowly then when i start to straighten out everything fixes itself. its as if there is a loss of power. rpms dont climb - what could it be?
    Is your car lowered? Are your tires wider than stock? Maybe your RF tire is rubbing on a hard left turn, causing you to bog down, either due to tire size, alignment, or an un-even or too low drop.
    ON_N20
    Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
      An outer CV joint that binds only in that direction and that degree of turn is an outside possibility.
        everything is stock. i actually have smaller wheels than the original. The left front axle needs to be replaced so ill get that done.
        Its somewhat like having a turbo. nothing in the lower rpm then as you continue, the turbo kicks in and you go. Only my car is stock. Its that feeling of nothing in the beginning and then there it is.
        Would the transmission have anything to do with this? Lack of a tune-up?motor mounts?fuel? Im kinda leaning towards these things.
          I might would guess fuel, since I had a Civic that did the same thing. We pulled the tank (had to pull it) and the pick-up screen was super clogged.
          Replaced the pump and screen and never had another issue with it.
          Might not hurt to pull the pump and take a looksee
          *Click on photo for my MR thread
            I had the same problem and it turned out that the screen had actually fallen off. Got a 255lph and it went away, I'm willing to bet your problem is fuel related.
            1990 Accord four door EX + JDM H22A + JDM LSD H22 trans: Born 08/01/2003 - Killed 11/12/2008
            1992 Accord four door LX + JDM H22A = New project.
              well i did a tune up- plugs wires cap and rotor. fuel filter rear motor mount and the thermostat-the car wasnt warming up right. since i replaced the thermostat i found that my tranny is going-and i cant wait till it does- swapping to a 5speed
