my turn signals are not working,i checked the fuses,bulbs,connections its all good, my hazards work fine ,i think its my switch at the steering colum how can i check if my switch is bad?
Turn signals not working need help
first off check, again make sure all the relays are properly put in, second check all the wiring to make sure no burnt or other things that don't belong there...If that's not the case....CHeck the signal arm buttom...it could be just that...Cause i had this promblem once...One of the wiring was no properly installed and became loose in time
VS
Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
i had the same problem with my wagon, c if ur flashers work, if so then ur relay and wiring is good. if not then ur first colprate would be to check the relay. but if they do work then, most likely its ur turn signal switchOriginally posted by CB7**33 View Postmy turn signals are not working,i checked the fuses,bulbs,connections its all good, my hazards work fine ,i think its my switch at the steering colum how can i check if my switch is bad?
Test the wires coming out of the turn signal switch. If they get power when you move the switch up and down, then it is doing it's job. Problem will be elsewhere. If it is not putting power out, and you're certain all fuses and relays are good, then the switch will more than likely be the problem. Hope this helps.
'92 Accord DX
