idle is going up and down
    hello CBTUNERZ, this morning after i warmed up my car and started rolling and then came to a stop light i noticed that my idle was going up and down from approx. 1100rpm to 2000rpm... what do i check or how can i fix this?
    This has been covered over and over and over again. A very common problem.
    Read the stickies in the beginner's section, it has the solution.
    Also a quick search and you'll get many more results.
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
      idle air control valve. search that up for diy cleaning
      miss my turbo cb7
        thanks you guys! i didnt know how to search it by or if it had a fancy name... but thanks again
          It could also be the TPS. Once you do the search it should help you in determining the source of the problem.
          '92 Accord DX
            its the idle air control valve. mine does it some time when i start up my car but then it goes away in a few seconds. i think that is a spring or some thing that u can tightin up and it should stop.
              You may also want to check your FITV = Fast Idle Thermo valve, it could be going out as well. My idle would bounce and I even took off the on the FITV and tighened the plate down for a temp. fix and still bounced, then I bypassed it and now I idle fine. Usually people replace the FITV because once it goes out there is no real way to repair it so they just go pick up a new one from the auto parts store or even try their luck at a junkyard. I just didn't really need it so I bypassed it.
              Good luck on trying to find out the problem.
              Originally posted by 92jdm
              if you have any mechanical inclination, it should be easier than a drunk highschool girl after prom.
                it could also be your distributor...do a cel test and if you cet code 9 then chances are it's your dizzy..or take off your dizzy cap and see if the dizzy shaft is loose.
                92 Accord EX - SOLD
                PSN: REDxMAN-_-
                MR===>http://www.cb7tuner.com/vbb/showthread.php?t=146478
