Engine Leak
    Engine Leak
    I recently topped off on Engine oil last month and it just leaked out. I noticed on the bottom that there was engine oil and rad fluid. I asked around at school and they told me it was a cracked engine block. I was wondering how much this would cost? and could this be sum thing else?
    thanks
    dont listen to others that say extreme stuff like a cracked block. thats pretty rare on these cars. its most likely a combination of leaks. id suggest cleaning any visible oil off with some brake cleen or similar and then see where the oil comes from. You didnt give much info as to where its coming from other than the bottom. oil is always going to come from the bottom due to gravity.
    member ride thread
    DIVULGE MOTORSPORTS
      If it's a cracked block, you're better off just replacing the entire engine.
      Where is the leak on the engine? If it's coming from the transmission side, it could be the rear main seal. If that goes bad, a leak would be severe.
        The Engine oil leak is right in the middle its on a pipe, and the rad drips over from the engine cover so i can't really tell. I put water in there for temp, that wont ruin anything will it?
          you really need to be more specific as to the locations and descriptions of things. right in the middle on a pipe tells me nothing, there are many pipes and hoses that can leak. Its probably not engine oil though because oil does not travel through any pipes on the f22a engine. Therefor i take it your car is an automatic?
          the radiator is not near any engine cover, hondas dont have engine covers for that matter. are you referring the the valve cover? if so say more about what side, whats around it etc. the more info you give the better your responses will be. even if you dont know anything about cars do your best to describe surrounding things so we can get some clue as to what and where you are talking about.
          member ride thread
          DIVULGE MOTORSPORTS
            If you don't know the names of the components you are referring to, take a picture, circle the areas that are leaking, and we'll be able to offer more assistance.
              Sorry for holding you guys up
              I gave it into the mechanic after if got really severe and they fixed it up
              they said that the radiator hose at the bottom came loose and the engine oil leak was due to the oil pump switch which was busted
              Thanks for all your help
                There you go, nice and simple. The "oil pump switch" is probably the oil pressure sending unit above the oil filter, by the way.
