problem with speedodmeter
    i change new cluster and i have no short all new speed sensors and this still dont work why ?
    plz help
    my rpm gas and temp gage work but no speedodmeter
    try putting dielectric grease in the plug for the speed sensor. The contacts sometimes are not connecting properly, this grease helps them make a better connection. You can buy a little packet of it for $1.25 at autozone which is more than enough
      thx man i will try that and see what happens!
        Did you fix it?
        Thanks,
          naw man no luck with that! any other suggestions
            Did you swap to a cb cluster or other, also did you check to see if the cluster is a denso or ns slightly different. If you still have the old cluster try installing it and see if it works. If it does then the cluster you bought is defected
            NEW CB
            old Darkcloud : 1990 Accord EX MRT
            new
            DARKCLOUD : 90 ACCORD EX MRT
