inline fuel filter ???
    i have a fuel cell with external fuel pump.. if i put a inline filter before the pump will i still get the right PSI?? and what should the PSI be after the regulator?? the reason for this question is that my pump was clogged so i cleaned it out and it ran like a champion after the cleaning. but i put a inline filter and now it seems to me like the motor is not getting the right amount of gas??? could the filter i put not work on fuel injection systems?? F#C&ING race car
    help me out guys ................... thanks
    It could be cloged some where in the fuel line, ya kno?
    Maybe try some sea foam, or lucas to get it cleaned.
    Temp sig, cars almost done
      you could, it shouldn't drop the fuel pressure if it's the right size...I wouldn't think.
      ____
        i pulled the hole fuel system apart and run air in the fuel lines they were clean so i changed the fuel filter on the fire wall and added the inline filter before the pump.. i think I'm going to take the inline filter out because it ran fine with out it.. i really think that the inline filter i got is not the right kind of filter to run on the fuel injection system what is the right size fuel filter???
        what PSI???
        thanks guys................................F#c% race car
          Originally posted by IAmTheNight View Post
          I don't know if you still need it or not but:
          From Haynes Manual
          1990:
          regulator vacuum hose attached-35 to 37 psi; regulator vacuum hose disconnected-35 to 41 psi
          1991-1993:
          regulator vacuum hose attached-30 to 38 psi; regulator vacuum hose disconnected-40 to 47 psi
          all stock though...fuel pump and all
          ____
            yup, if you have a high flowing fuel pump like a 255 it'll kick that pressure up to like 55psi, a 190 will even make it rise 5 or so psi so if you have an aftermarket fuel pump, then you need a AFPR
