Coil overs
    Coil overs
    I used the search but could not find my answer. May sound stupid but I bought some used coil overs and wanted to know if the longer spring goes on the front or rear.
    Thanks Monza
    MRT - http://www.cb7tuner.com/vbb/showthread.php?t=172713
    1993 Accord Ex
    The longer spring goes in the rear.
    What brand are these coilovers? If they are a cheap no-name brand, be careful... if they fail, you crash. I would NEVER trust cheap crap on my suspension. Additionally, you would be VERY wise to replace your stock shocks when you install them. Lowering your car on 18 year old stock shocks is incredibly dangerous. You can easily lose control of your car.
      Thanks for the quick answer, I have KYB AGX's on the car right now. I hope they will be good enough.
      1993 Accord Ex
        They're not made to be lowered more than 1.5", and they're not designed for a very high spring rate... but they're a hell of a lot better than stock!
          x2
            Originally posted by CB7tom View Post
            x2
            I don't need backup. Posts like that WILL get you banned for post whoring.
              Please exercise caution when running coilover sleeves. They sketch me out
              life is good.
                I have some question about my what shocks to buy.
                Two weeks ago I bought some cheap coil overs the brands is Bomz Racing. They lowerd my car. But i kept the stock shock and my car is boucing like hell. I want to know what should I do. Should I buy complete coilovers or buy KYB,KONI,SKUNK2 or whatever you guys recomend. Please help me out the boucing is making me crazy please help me.
                  make a new thread for this, you wont get much help in a thread thats unrelated
                  _
                    Agreed.
                    However, since this guy's life is pretty much in danger... I'll reply.
                    1) you NEED better shocks. You will lose control of your car under hard braking or turning with blown shocks and stiff springs. Lowering your car on stock shocks is one of the most idiotic things you can do.
                    Get shocks made for lowering. Basically, anything made by Koni will be good. STR-Ts are quite inexpensive.
                    2) Get real springs, or coilover sleeves made by Ground Control. The garbage you just installed is just that... garbage. The spring rate is very high, and the quality is very low. If one of those springs or perches fail on you, you will crash. If they sag and cause uneven tire wear, you may crash.
                    3) get an alignment. A camber kit AND an alignment would be best, but at the very least, get an alignment! Otherwise, your tires will wear very quickly. Without a camber kit, your tires will wear quickly on the inside. Since the inside would be the primary contact patch, your tires will be done once that gets low... even though the middle would appear to be fine. Tires will wear much faster that way. If you don't want to replace your tires every 10,000 miles, and you don't want to lose control of your car... I strongly urge you to buy a QUALITY camber kit (Ingalls or SPC... not $30 ebay bullshit... if that breaks, you crash...)
                      help
                      i just got my koni yellows in and im looking to get prbly some ground control coilovers where are the cheapest place to get them? im also lookin to do a big drop also so i think the 3.5 inch drop will do fine?
                        This should answer your first question
                        http://www.cb7tuner.com/vbb/announcement.php?f=107
                        Your second sentence is merely a statement followed by a question mark. It is not a question, therefore there is no answer for it.
                          i was just wondering if there was a web site selling the ground control coilovers cheaper then ebay or a google search.
                            Right. That's usually why people ask where they can buy things... but it doesn't change the fact that it's against the rules here.
                              ok some applications say that the ground control coilovers are fore shock number 1,2,3,7,8,10. which number are the koni yellows? hear is the link
                              http://www.nolimitmotorsport.com/gro...pps-Honda.html
