EGR port plugs... What the hell...
    Why honda???? Why did you make the 7th hole bigger? WTF?
    I bought 7 plugs from TASauto only to find out the 7th hole was bigger and the plug was too small.
    I had a spare seat bolt and rammed it in here. Is this safe?
    no, lol. take bolt back off, tap it for 1/2" pipe and throw a pipe plug in there.
      Why wont this work? Its pretty wedged in there right now.
        because it is hack.
          because it is hack.
          Are you reffering to it looking like shit?
          Im not really concerned how it looks lol. As long as it dosent leak and i can drive the car without any chance of a problem. Thats ALL i care about. I should have never taken my car apart to start with and i need to get it back together tomarrow. I dont have immdiateaccess to anything that i could tap the hole with.
          All im really conerned with is: Will this work yes/no.
          Air is being sucked into here so the bolt wont have any pressure push it out will it?
            until egr is applied...then it becomes positive pressure. it should be fine. i would have applied silicone and then rammed it in. Actually i would have tapped it for a 1/2" pipe plug.
              lol.
              Would RTV sealer work around the end of the bolt?
                will if it is already forced in, i wouldnt take it back out. you could pull aluminum, break the bolt...etc.
                while it is running, squirt some water around the bolt and check for leaks.
