I have a 93 ex coupe with a 5 spd transmission that loses power as the car continues to run. Let me give more details. the car had about 142,000 miles when i bought, and the transmission went out on it shortly after. I replaced the transmission, and it was running just fine, however it was leaking fluid. I discovered that the leak was coming from the transmission seal for the driverside axle. So over the weekend i replaced it, and the transmission no longer leaks, however for some reason the transmission now no longer puts enough power to the wheels. The gears slug between shifts before it tries to catch it seems and the longer you drive it the worse it gets. eventually you're just high revving and not moving at all. Anybody ever experience this? If so please advise on a solution. This is pretty much my last resort before deciding to part with it.
5 Spd transmission problems.
