Quick ROH question???
    Getting the hub and bearing, so now i just need some 98-02 accord Rotors and 4 attaching screws correct??
    Also since i'll be replacing the wheel bearing i should be able to just hammer the old one out without using anything to protect it??
    Is this the front or rear?
    Rear is Prelude Hub/bearing assembly with Accord V6 Rotors and yes 2 screws for each side.
    You CANNOT damage the spindle, your new bearings will be destroyed
    Your man for wiring solutions!
    CB7Man's Coupe H22 Swap
    CB7Man's Sedan Resurrected From The Dead
      for the front, i'm getting the kit from TAS.
        Yello
        I have a 93 accord 2 door...
        OK so I want to do the swap and need to confirm some details...
        I just need (2) 98 Acura CL hubs and (2) 1990-1998 Accord Front wheel bearings and get them pressed onto the hubs right?
        Then I will need to shop for 98 front Acura CL front discs and 93 rear discs.
        (probably both cross drilled)
        4 rotor set screws, 2 for each side
        (you only need 1 per side....they just hold the rotor in place until you bolt the wheel up)
        ..and BAM...no more lame ass brake setup.
        If anyone wants they can post links to revelant similar threads.
        I saw this first here:
        Honda Accord (1990 - 2002) - DIY - Rotor Over Hub Conversion - I just finished my Rotor-Over-Hub Conversion today, and I took pics along the way, so I figured I would share it with you guys, and maybe help some people out. I also noted that in the Guide to Basic Accords, the R-O-H conversion link is actually from...
          4 rotor positioning screws total (2 per side).
          You could do the "hammer out" old hub/bearing assembly method since you're installing new hub/bearing assembly. I'd use a spare set of screws (not the originals!) and make sure to thread them well before hammering them out. Hammer out evenly and line up the hub/bearing assembly so it comes out, pay attention to the bearing flange shape and align with old rotor inside portion for this to remove smoothly.
          In more corrosive environments, you may need a press for this process.
            ^Yeah, def. use a junk set (4) of M10 bolts and tap on the heads of them in an even criss-cross pattern, you should be able to remove the entire hub/bearing assy from the knuckle. Do not use the the orig. bolts to hammer on, those are special and the metal will peen over. Heat and liquid wrench are your friends if things are heavily rusted and frozen aswell.
