Head Swap Tips?
    Head Swap Tips?
    hey guys, so yes i've been searching around. fairly new to the breakdown/teardown process and rebuild process. i've only swapped a few B's and helped tear apart a saab motor with my brother so bare with me...
    going with a rebuilt A6 head, this is my DD so nothing crazy over here. it comes in in about a week. any advice? i'll also be ordering a new honda water pump, timing belt, a head gasket, new head bolts, cam seal, and a couple other parts.
    i know to obviously cover the block so no dirt gets in, or use acetone to try and clean the top deck up but other tips and tricks would be helpful as i'm new to this especially getting the head gasket to seat right and stuff. i've got a haynes manual as well.
    tia
    life is good.
    Be sure to loosen and tighten the bolts in the correct order. Don't rush it.
      get the Fel-Pro Torque tables book from your local auto parts store AND a quality torque wrench. Try to keep everything spotlessly clean and follow the instructions to the letter and you should be ok to go.
        ok thanks guys, i'll update when it's put back together
        life is good.
