Stray Vaccuum Line
    Stray Vaccuum Line
    Hey, on the little black box above the fuel filter there are vaccuum lines coming out of it. The 2 lines on the bottom are labeled 3 and 16. Where does 3 go? It's just hanging loose and I can't find where it's supposed to be. there is a broken plastic piece on the loose end.
    thanks
    short
    Broken plastic piece is probably the nipple of where that vacuum line should go. Considering the only plastic nipple in that area goes to the fuel charcoal canister below the emissions black box. You're going to have to get another canister then...
      You could always just remove the canister all together and not have to worry with it.
        Yup, it's off the canister, I don't know how i missed that I was just looking around the intake i guess. Would this cause any issues like lower gas mileage or what cause I have no idea how long its been like this lol
          i removed my canitster and i havent had any problems with gas mileage dropping or anything mine has been this way for 4 months now but then again i deleted the map sensor box also
          what shall not
          kill you shall
          only make you
          STRONGER
            There is absolutly no point in removing the canister. It dosent affect preformance at all. All it does is take gas fumes and put them back into the gas tank vs putting them into the atmosphere. You arent driving a high preformance vehicle where every bit of weight counts so just leave it in. If you want a lighter vehicle then lose some pounds yourself.
              I meant is anything affected by that line not being hooked up to the canister. Should I plug it up? I'm not removing anything if I don't have to, so calm down Tippey, no need to call me fat lol
              short
                I removed mine but it was in no way performance related. I simply did it to get rid of shit under the hood that's not needed for a cleaner look. It doesn't do shit t begin with and your exhaust is polluting the air enough as it is that it's really of no concern.
