pt6 or p14 ecu?
    pt6 or p14 ecu?
    hey guys i have a 93 accord ex with an h23 swap. i just took the ecu cover off to find out its a pt6. should i get a p14?
    thanks
    -steve
    It would only make sense, look for the P14 from a 92-96 Prelude Si.
    You buy this vehicle with swap already done?
      It will run on the PT6, as I'm sure you've already learned... but it won't run properly. Driving it regularly on that ECU may cause damage. Get a P14 ASAP...
      or if you have a capable dyno tuner in your area that is familar with the H23, you can get a P06 ECU and have it modified and tuned... but if you're nearly stock, you really don't need to worry about that.
        to honda fan yes i bought it like that.
        to deev. i already just bought the p14 but the connectors dont line up. what should i do? also the car is completly stock. what do i need to run the p14? is there a wiring thread?
        thanks for all the feedback guys!!
          The connectors should line up. Be sure you have an OBD1 ECU. I would assume it's an OBD2 ECU, because the PT6 is ONLY OBD1... if that's plugged in, then your harness wasn't converted.
            i was looking at the pt6 & the p14. the pt6 has 2 rows of pins. while the p14 has 3 rows. does that mean the p14 i picked up was obdII?
              http://www.hondata.com/techecuid.html
                awesome thanks a lot deev. i have an obd2 ecu. ill go pick up a obd1 ecu. if i switch to the p14 how will my car run?
                  Properly?
                    Assuming the engine is still healthy, and all your sensors are functional... it will run as it is supposed to run. The ECU doesn't know that it's not in a Prelude... it simply controls the engine. The P14 is made for that engine.
                      one thing in worried about is the knock sensor.i dont know if its connected. do h23's use a knock sensor?
                        Yes, they do.
                          sorry for all the questions. is there a difference between an auto p14 and a 5-spd p14? thanks
                            Yes, there is a diff. between auto and manual. For manual Accords and Preludes, you can run auto or manual ecu's. For auto's, I'm not sure if you can do the same. But auto ecu's I believe are mapped differently to shift smoother, manual ecu's are more simple. I would suggest getting the proper ecu for your setup. Maybe someone could chime in w/ an auto using a manual ecu, if that's even possible Also, you know how to read the #'s correct? Above A50 is auto, anything less than A50 (usually around A00-A11) is manual.
                              I've heard a few people say that the ECU doesn't matter, since the TCU controls the transmission... but I have yet to hear that from someone that is really an expert in such things. Getting the proper ECU would be the best option.
