Hesitation problem
    Hesitation problem
    ok i have a 92 ex couple 5 speed, while driving after awhile, the car would hesitate and miss really bad, what i usually do i just turn the car off an back on while driving and it would stop, that usually fixes the problem, but what would be causing the car to be missing and hesitating like that? i change cap, rotor, plugs, wires,fuel filter.... but i am throwing a code for o2 could that be the problem?
    Originally posted by steezyteg
    lmfao rota 5 star dude theyre called rota slipstreams
    I have never seen an o2 code cause the car to miss. When u changed the plugs did you check to make sure the gap were correct, or if their is oil getting into the spark plugs. Also i am not sure if your car has an external coil pack. Some time those crack and cause problems. but when this happened to my car it was my dizzy. The voltage regulator was cracked.
      well if your getting a code start there hopefully thats where the problem lies and not anywhere more serious
      I know that you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant.
        ok well my car is external coil, i did gap the plugs corrrect, there is no oil in the plugs, i will check the coil and make sure thats good, also the codes its throwing is for o2.....and it only does this on like really hot days so idk what is really goin on....i will look into it a litte more and let you all know what i com up with.
          i was reading could a bad temp sensor cause the car to hesitate and miss like that?
