Is it possible to overfill the transmission fluid? Like if i only jack up one side of the car and fill it? Will that slight overfilling hurt anything? Thanks
Overfill tranny fluid?
im not 100% sure on this but i dont really see an issue with it.....i mean there isnt really and pressure building in there. Its all for lube right? More lube the better? On an auto im assuming different story but on a 5 speed i dont really see an issue....maybe someone can chime in with some facts instead of thoughts
for a 5spd, unless you are severely overfilling you should be ok.
worse comes to worse jack it up on a level surface, fill till it starts dripping out of the fill hole, place a drain pan, drop the car and let it drip out till its only a drop or two at a time, jack back up and replace the fill plug.
Bought from: Bisimoto
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
