Im hooking up a python 991..
I've got a few questions..
I know you can get to the tach wire from the engine bay.. Or you can also hook up to the wire going in gauge..(remove the bezel and etc etc) There's a brown plug in the drivers foot well on the right side of the steering column.. It contains a blue wire.. By any chance is that usable for tach?
The alarm has a positive brake shutdown input.. is the wire for the parking brake positive and would it be able to function for the brake shutdown(put the parking brake down.. car turns off..while in remote start mode)
The alarm produces 200ma for the horn output wire.. This means that there must be a relay before connecting the alarm wire to the horn.. Since the horn is already on a relay could I just connect the 200ma wire to the (insert wire color) wire on the horn relay?
This is the same question i have for the rear defogger output..
The alarm also provides a 200ma wire for (-) status output .. This goes to the clutch kill wire.. Is that enough current to trigger the desired effect(clutch kill switch bypass) or does a relay need to be added to this?
*** UPDATE **
To properly bypass your clutch you MUST wire a relay..
87a N/C
87 1 of your clutch wires(Dont Connect Together With Other Wire Or You Will Waste Your Time And Blow Your Starter Fuse)
30 The other clutch wire(Dont Connect Together With Other Wire Or You Will Waste Your Time And Blow Your Starter Fuse)
86 12V Power
85 (-) Status Output from Alarm(It's dark blue on python 991...viper 5901..clifford 50.7x)
If did/do this incorrectly like I did.. You will fry the circuit on your alarm brain that controls the status output and the 2nd status output.. Sucks..I know..But you can still get your remote start working by connecting 85 to a ground(wire to a piece of metal..lol) .. This disadvantage of this is that your clutch kill switch is now bypassed at all times.. So you can start the car like you would an auto vehicle.. Maybe you want that.. I dont.. And I dont think our cars are like the other hondas that can just be grounded by hooking up the status output to one of the clutch switch wires.. And your alarm is probably only give you one chance to make a mistake.... If you decide to take the shortcut then you will probably fry your alarm circuit on the first try like me
Now fuckups can be forgiven.. Due to my error.. I will not be having rear defroster in the winter time..
But I can have my clutch switch work like OEM and have my remote start.. My alarm brain had a (-) 200ma Starter Output.. Which functions like the (-) status output...(for what im trying to use it for) So if you do what I did and substitute the starter output for the status.. Your car will not start unless the clutch is pushed in ,but \ it will also remote start without the clutch pushed in
If you do not know where the clutch switch is.. IT's located on the clutch pedal.. There are two different plugs on the the clutch pedal.. The one higher up of the two is the one that you want.. You can test this theory by unplugging one of them and then trying to start the car.. WHen the correct one is unplugged.. You will not be able to start the car.. If you have a 10mm Socket available I'd recommend you use it to remove the bolts on the silver box so that you will have more room to work on your switch.
__________________________________________________ ____________
If your alarm is like mine..(python 991) If you ground the neutral safety wire to the parking brake wire.. and hook up the alarms pos brake wire to your car brake wire.. Then it'll turn your car off while in remote start mode if the brake is pressed and/or if the parking brake is pushed ddown.
__________________________________________________ ______________
THe horn portion of this post.. I haven't done yet.. So I cant answer it.. And if you dont like fucking up your shit.. I'd say use a relay.. I learned from fucking up the first time with the status output.. That shortcuts suck if you fuck up.. Just add the relay.
*** UPDATE **
87a N/C
86 12V Power
But I can have my clutch switch work like OEM and have my remote start.. My alarm brain had a (-) 200ma Starter Output.. Which functions like the (-) status output...(for what im trying to use it for) So if you do what I did and substitute the starter output for the status.. Your car will not start unless the clutch is pushed in ,but \ it will also remote start without the clutch pushed inIf you do not know where the clutch switch is.. IT's located on the clutch pedal.. There are two different plugs on the the clutch pedal.. The one higher up of the two is the one that you want.. You can test this theory by unplugging one of them and then trying to start the car.. WHen the correct one is unplugged.. You will not be able to start the car.. If you have a 10mm Socket available I'd recommend you use it to remove the bolts on the silver box so that you will have more room to work on your switch.
.. But I do have 4 more to use.. I got the dei 530t which I'll wire up after I finish the alarm.. So at least i'll get automagic windows..
