how do i stop this shaking? is it my motor mounts? is it expensive to fix or can id o it myself?
car shakes at stoplights
Check and inspect the front motor mount in particular, the one in front of the headers. Those ones always fail. So you say that it only shakes at stoplights? Usually when idling? Need more info regarding that. But, motor mounts are pretty easy to replace if you know what you're doing. They can be kind of complex to get to though.'91 DX 4dr, brown on brown
+2Originally posted by eddierod04 View PostIs your car an auto? The front engine mount ,by the fire wall, is notorious for breaking. When i did my auto to manual swap, the mount fell apart. Grab you intake from the back see if you can pull the motor forward, if you can its guaranteed that its the mount.
My rear is dead, going to take care of it with the motor swap.
Also make sure you idle isn't to low.
Robert
