power steering delete?
    my ps pump went out this mornin so now i just wanna get it outa my bay is there a DIY for this and if not can someone help me out thanks
    Why dont you just replace the pump and keep you power steering?
      i really dont have the money for it righ now just got a new tranny and clutch so m broke
        [/URL]http://www.cb7tuner.com/vbb/showthread.php?t=151842&highlight=power+steering+d elete[/URL]
        boom!
        search for it and thy shall receive
          first thing is you need to pull off the belts, and yes all of then because the stering belt in behind the others. then there is two bolts holding the pump so remove them and then just remove the high and low pressure lines and your done.
            you will need to keep the fluid in the rack and have a way to ensure the rack doesn't run dry as a result of a leak...which is likely to happen.
            The easiest thing is to just take off the belt. You can use the reservoir tank to keep an eye on it.
            You could then run the lines from the pump so they directly run from the rack to the tank and then remove the pump.
            Rebuilding a pump is not expensive if you do it yourself btw...I need to rebuild the wifes 00 accord pump too.
            ____
