The fan comes on and stays on until I disconnect the battery. After I drive the car it stays on indefinately. Is it some fan timer switch located under dash ? or is there some fan timer under the driver seat ? Or what could it be ? Thanks for the replies.
Driver side fan "ON" without being started.
its in the engine bay.
member ride thread
DIVULGE MOTORSPORTS
I'm sorry, it's the cooling fan, and I don't know if this is cool but it's my 89' Accord that's giving me this problem. I really need help so I can sell it A.S.A.P., my 91' needs a little work . ThanksOriginally posted by mattman View Postare you talking about the cooling fan? or the interior? as far as i know.. there is only one fan in the interior.. it sounds like a wire is loose .. does it change fans speeds when you turn the dial?
The fan thermoswitch might be stuck "on". It's the one on the front of the engine where the upper rad hose connects. Try unplugging it and see if that helps. That thermoswitch is for turning the fan on after you shut off the car so unplugging it won't affect the fan from coming on while driving.
Bingo! I vote this ^ for the solution ..Originally posted by YK86 View PostThe fan thermoswitch might be stuck "on". It's the one on the front of the engine where the upper rad hose connects. Try unplugging it and see if that helps. That thermoswitch is for turning the fan on after you shut off the car so unplugging it won't affect the fan from coming on while driving.
__
