I was driving and my car sputtered out. So i put it in neutral and pulled over. the check oil light came on (To the immediate right of the battery light) after getting home from a tow, i checked my oil and it was below the lower hole on the dip stick. When i try and start the car it doesnt sound normal. it sounds week and like the only thing turning is the starter and fly wheel. My accessory belts are turning slowly as i try to start. So i pulled off the valve cover to see if the cam is even turning, its not!
I think it might be a timing belt issue.
Fule pump is fine, distributor is new, starter is new, plugs and wires are new.
ANy help on what the problem maybe will greatly help me. I need to get this CB fixed! im getting sad with out it.... and work is a bitch to get to now.
