Fuel Cut-Off Relay
    Fuel Cut-Off Relay
    I'm trying to test my fuel pump and I cannot find the fuel cut off relay, per the service manual.
    Chilton also says this:
    Remove the screws securing the under dash fuse box to its mount. Remove the fuel cut-off relay from the back of the fuse block and turn the block so you can see the relay mount.
    Does anybody have a better description of where this relay is. I've done a lot of searching and I've come up empty handed. A lot of people have said it's the same as the main relay, but the pins clearly don't match the image.
    search for "main relay" in DIY section....
      It's actually the Main Relay that controls this and it's directly under the coin holder under the dash (In that direction). I forget what you have to move out of the way, but it's not difficult and actually in plain view once you know what you’re looking for. I know exactly what you’re going through, I had the same picture and must have went under that dash numerous time before I found it. It was right in front of my face...LMAO
      Ps...Let me know if u'd like me to take a pic of it's location & I’ll see what I can do as my beast is gonna get some more lovin' soon!
        If the main relay is in fact the same, how do I account for the fact that the pins aren't the same as the ones pictured?
          Never mind. I found a different page in the service manual which gives the correct pin connections for testing the fuel pump.
          Pg 6-215... if anyone comes to this later.
