I have a 1992 lx accord with a h22a 5 speed with a p13 ecu, (Which i found out it came out of a 4ws prelude) my question is does this ecu have different setting because my h22 redlines at 6500 instead of 7200 and it doesnt seem like its running to its full potinental...I do have two codes on,which is o2 sensor and 4ws.. Anyone have any ideas?
another quick question
Fix the O2 sensor code. That particular code puts the motor in limp mode. VTEC won't engage, so the motor is limiting at 6200 RPM.
The 4WS code won't throw the CEL, it will only come up when you go to check the codes.
Putting in a chipped P28 at this point will NOT fix your issue. Get the motor running right before you do any mods like that, so you know if the problem is the motor or the ECU. HDeuce2, was that a post whore move or did you think that it would really fix his problem?Last edited by 4GAccordH22; 06-15-2010, 05:10 PM.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
Originally posted by 4GAccordH22 View PostFix the O2 sensor code. That particular code puts the motor in limp mode. VTEC won't engage, so the motor is limiting at 6200 RPM.
The P13 is a perfectly good ecu for the H22. The 4WS will not affect performance and will not actually light up the CEL.
I have nothing against chipping and tuning, as I was running a P72 with a Hondata S300 tuned by Jei at Blacktrax. I just found that it required constant tuning as the weather changed and when the gas was switched from summer to winter gas (they do that here in CA). I switched to a USDM P13 and found it to run better in the long run as the ECU can learn and adjust to changing conditions better than the Hondata did. I will probably get the Hondata re-tuned for a full race ECU and swap it out when I go to the track, but for daily driving, I prefer the P13.
HDuece2, the reason I questioned your post is because it did not even attempt to answer the original question. If you had originally said what you said in your reply to MY post, I would not have. The OP is not yet at the point where he should even consider swapping ECUs. Deal with the issues at hand, then look at performance and how to improve it.Originally posted by Junior SmurffNevermind guys, google search works wonders!
^^Switching ECU's will NOT fix the issue. He should fix his current codes (O2 sensor, not the 4ws) and go from there. What makes you guys think running a cheap chip in a p28 is so great? Hondata s300 and a tune is one thing, but a chip is just half assed. I would rather run a p13 then a ebay chipped p28 anyday.
Originally posted by Blamo View Post^^Switching ECU's will NOT fix the issue. He should fix his current codes (O2 sensor, not the 4ws) and go from there. What makes you guys think running a cheap chip in a p28 is so great? Hondata s300 and a tune is one thing, but a chip is just half assed. I would rather run a p13 then a ebay chipped p28 anyday.
I've had 2 H22's and 1 European H23 Vtec in my CB over the past 8 years and have done multiple test on a dyno using P13, P72 (Chipped, but NOT EBAY), and P28 (Chipped, but NOT EBAY). The result was this…The P13 chocked the motor out and the P72 & P28 were like night and day with the P28 slightly out performing the P72!
Conclusion is this.....
-Fix the O2 problem FIRST!
-Once that is resolved, do your research and ditch that P13 that will always hold your motor back!
