what do you guys recommend i have a jdm h22 currently has regular oil and i want to know if i should switch to synthetic or stay with what i got planning to do oil change tomorrow any input would be great thanks in advance guys
got a question about oil
It really doesn't matter, as long as you get the proper viscosity. Synthetic oils tend to find existing leaks faster than regular oil... so if you have any leaks, you might not want to go synthetic.
I run a synthetic blend in my H22. Not for any real reason. I just feel better having a little extra protection. I still change the oil every 3000-4000 miles.
Now in my Fit, I'll go 10,000 miles per change with synthetic. Granted, that's about 5 weeks.
Thanks man needed to know a good answer cuz alot of my friends said that synthetic is better and just making a big deal out of it they say that its cleaner and stuffOriginally posted by deevergote View PostIt really doesn't matter, as long as you get the proper viscosity. Synthetic oils tend to find existing leaks faster than regular oil... so if you have any leaks, you might not want to go synthetic.
It is, to a point... but it's really not necessary unless the engine was designed to use it. If you plan on running your engine REALLY hard, in extreme heat, or going longer than 5000 miles between changes, then synthetic would be smart. Otherwise, for normal use, traditional oil will be just fine. Just get a quality brand.
deevergote, what kind of blend are you running?Originally posted by deevergote View PostIt really doesn't matter, as long as you get the proper viscosity. Synthetic oils tend to find existing leaks faster than regular oil... so if you have any leaks, you might not want to go synthetic.
Robert
