i think i blew my head gasket on my 90 accord.. if it is the head gasket about how much would it cost me to get fixed.. whats going on is i turn on the car let it idle then after a few mins it overheats and then hella steam comes rite out the motor
Head gasket ??????
get a new one asap you don't what to cause cavitation or any other horrible damage to your engine like hydro-locking with coolant or melting into a puddle* (exaggerating just a tad bit) as for the price depends on were you get the part or who does it for you
1990 Accord EXOriginally posted by deevergoteHe's disappointed in my bulge... it doesn't even come close to being as impressive as his.
1996 Civic hatch *gone*
1994 Integra
What?Originally posted by HDuece2 View PostIf you perform the work yourself, you shouldn't spend more then $100. Make sure the overheating didn't cause your head to warp. That's when things will get more expensive....
How do you figure?
You really should have the head surfaced to ensure it's perfectly flat to promote a good seal, you'll need fresh coolant. A good headgasket from Honda is around $70. You'll also need a new intake gasket and new exhaust gaskets. It would be stupid not to do the timing belt and WP while everything is apart, unless they are virtually new.
I really just have a hard time seeing this done PROPERLY for under $100.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
The price of $100 is to change the head gasket only if performing yourself, nothing more....But I would always recommend having the head inspected before changing the head gasket. I think most would agree on that price!Originally posted by foamypirate View PostWhat?
How do you figure?
you can go to the auto parts store and get a new head gasket kit with every gasket you need for the entire head and it should only cost you about $100 bucks...keep a jug of water with you until you get it fixed and keep an eye on the temp if you're stioll driving it...foamypirate is right as well you should really get the head resurfaced as well or atleast make sure that it's still level and not warped...clean the old gasket residue of the head etc.
is there a how to thread about changing head gaskets cuzz ill try if a had directions, cuzz ive been getting quotes to get it fixed and the cheapest ive got is 800$ so far.. so if i can do it myself that would save me hella cash....Last edited by AcCoRdKiD916; 06-16-2010, 07:42 PM.
I have to agree with foamypirate I just finished doing just that job on my '90 LX, and if u want to go with felpro gaskets, the head set runs from $140.00 to $165.00, now that includes ALL of the gaskets u will need to get the job done the correct way...Now I did get a head set on ebay which even included the injector o-rings and gaskets that I didn't even need for $45.00, I did complete the job and was able to run my car for 2 weeks but unfortunately the bearing on rod 1 went out so now I'm opening the bottom of my engine to get that fixed. Now yes u must get ur head resurfaced and I would strongly recommend getting it pressure checked also just to go on the safe side and not have to redo the jobs a few weeks after. I had the head done for $130.00 with pressure check and valvce seating and stems replaced...Also as foamypirate says do the timing belt and water pump also. u dont want too have to pull everything out again to replace to WP... hope this helps...good luckOriginally posted by foamypirate View PostWhat?
How do you figure?
I really just have a hard time seeing this done PROPERLY for under $100...........
.................................................. .................................................. ...God First, Family Second, and CB's for fun Third...
