white smoke help please
    alright well i took my car around the block to make sure my new a/c pump is working fine. i come home park the car. go to turn it back on and the car is bogging sounds like it wants to shut off and it blowing white smoke. if i push the gas it goes up through the rpms but still blows the white smoke.
    what is the problem here
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    could be a really bad head gasket.
    my new turbo build
      but i just replaced it like 5 months ago. this blows
        did u put it in backwards?
        my new turbo build
          Check this
          Might be the rings.
          Get a compression tester and test all four cylinders
            white smoke is an indication that its burning coolant. Check your oil for discoloration {milky}, then check your coolant reservoir for oil. Then go from there-check spark plugs, compression check, etc. Most likely a head gasket like they said.
              mine did that the day it gave out on me..white smoke
              when I took it apart the headgasket was done for..
              Rush
              Originally posted by Darkcloud
              Bought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
              Originally posted by bmxicansd
              so you got a boombox, sunglasses and rosettta stone?
                x2 that all points to the headgasket
                  i do not believe it is the head gasket. if it was the head gasket it would be blowing smoke the whole time i drive it.
                  this doesnt do it everytime i start up. just sometimes and it stops after so long.
                  still believe its the headgasket?
                  because i had a headgasket blow on me before and all it did was drive real bad and smoke the whole time i drove it
                    just for your future reference man, white smoke is burning coolant, black smoke is rich mixture/blueish smoke is oil...
                    if anyone has had any other color exhaust I would love to see some pictures
                    My 93 CB7
                    My 79 Continental
                      well i am not replacing this headgasket i am having a shop do it. to much of a pain in the ass
                        did u clean the surface of the block wen u changed it cuz most of the time people get so caught up in the work they forget to do
                          Originally posted by HrMotorSports View Post
                          Might be the rings.
                          Not with white smoke, if the rings were bad she go through oil like a fat man does twinkies and she would have no power what so ever. But the compression is a good idea anyways, that will let you know if it's the HG or something far far worse.
                          "The Turtle"
                          DD/Trail Rig/Mud Bug
                            could it be the fuel filter? because head gaskets do it all the time right?
                              ok new update i have found some oil in my spark plugs. but my oil does not look milky.
                              so what it my prolbem? still head gasket?
