H22 automatic swap into CB9 chassis?
    Hi all.. pardon my newbness..
    I just got this wagon and #1 cylinder is dead on compression.. car runs.. and drives fine while moving but runs really ruff at idle.. when not in gear..
    Almost like its caming.. anyways..
    I was looking at buying a complete Automatic H22A swap for around 1100.00 ship with everything... but axles..
    Ecu and wiring harness and all..
    Now.. how to make it fit into my wagon?? would the front torque mount work???
    Does it bolt right up?? or will I need special mounts?? special axles??
    any info would be greatly appreciated thanks!! I dont want to order a motor that would be a hassle to install..
    DooDoo
    nobody?
    DooDoo
      You've been a member for 3 years... you should be aware that there is an entire section dedicated to swaps, and the H22 swap is written out in detail. Read through that, and come back with questions.
