It's official... my car is dead. Her block and head are so warped that coolant is just pouring out between the head and cylinder. So I need to put in a new engine, and I'm considering doing the H22 swap since I have to take out her engine anyways... How long will it take me if I am doing it all myself? This will be a weekend and after work project, so maybe a couple weeks. Or should I save time and money and may this guy 1,100 to just put in a f22a with 35k mi on it.
My block and head are warped... swap for H22?
Originally posted by 91dxaccordcb7 View Postnice car the f22a looks like a good deal the h22 is a good motor but in my opinion if i was going to do a swap i would put in a k series just for the fact of horsepower but in the end it all comes down to you and what you want to get out of your car
Anyways, F series engines are very cheap and the swap is in and out shouldn't cost you $1,100. I really suggest doing it yourself. Also with the H it is gonna still easy swap just going to cost you some more money. Also there is the option to get the block and head resurfaced flat, I don't know how much it would be at a machine shop near you but here it can be done for a couple hundred max.
My opinion if you have to swap I say do the F because of your budget and when you have the money you can modify it the way you want.Originally posted by 92jdmif you have any mechanical inclination, it should be easier than a drunk highschool girl after prom.
Originally posted by 92-Accord-LX View PostIt's official... my car is dead. Her block and head are so warped that coolant is just pouring out between the head and cylinder. So I need to put in a new engine, and I'm considering doing the H22 swap since I have to take out her engine anyways... How long will it take me if I am doing it all myself? This will be a weekend and after work project, so maybe a couple weeks. Or should I save time and money and may this guy 1,100 to just put in a f22a with 35k mi on it.
Originally posted by southsidecb7z View PostI say go with the f22, do the swap yourself though, pretty low miles too
You should have no problem finding a cheap H in LA... I would get one there and do the swap myself. There are a shit ton of CB7Tuners out there who could lend a hand + possibly find you a good deal too. All the work will be the same pretty much; the motor + ECU will just cost a couple more hundred dollars.
Originally posted by gloryaccordy View PostWhat's your budget + mechanical skills + timeline like
Def can't spend much more than 2,000 at this point. I am pretty mechanically inclined, but i haven't attempted anything of this caliber yet. I have a Suzuki Bandit 1200 that I will be using to get around for now, but I want my CB back, so timeline is just as soon as possible for me.
Anyone have any advice on what else to get other than the H22/tranny/ECU from Hmotorsonline
id say have a shop deck, hone with new pistons and reconditioned rods. have them assemble the block without any seals. you can put new seals on yourself. this should cost around 500 labor.
buy a reconditioned head for around 200 dollars and torque it on with a headgasket, check the valve lash and be done with it.
Pull your motor. Pay roughly $1000 to have Darton sleeves installed. Drop another $700 on forged rods and pistons. Spend $50 on a used head, and have it reconditioned.
Pricey, sure. But you'll be able to build one hell of a turbo-ready motor.
If you want to go the H22 route, hmotorsonline.com really IS your best option. There are cheaper places out there, but you often get what you pay for. Some get lucky... others get $1200 paperweights. Some places make things right... others give you the runaround. The risk wouldn't be worth the potential savings to me, but you may think differently. I've had an H22 from hmotors in my car since 2003... I beat the living piss out of it for 100,000 miles, and it's from 1994. The only problems I have ever had with it, I created myself.
Dude....stick with the F22....and boost that sucker. I guarantee that you can get a boosted F22 for under $2000. And you'll be mopping up H-series cars all day!1993 Accord LX *Under construction*
http://www.cb7tuner.com/vbb/showthread.php?t=162083 <---MRT
i have rarely seen a f22 block warp ,if you overheated it that bad your front covers at the t belt will be melted,what i would do is remove the head and clean the block ,use a straight edge and check the block if you can fit a .004" feeler gauge anywhere on the block the block needs to be resurfaced ,if not have the head checked for cracks and resurfaced and use a honda gasket set and put it back together......
Originally posted by wed3k View Postid say have a shop deck, hone with new pistons and reconditioned rods. have them assemble the block without any seals. you can put new seals on yourself. this should cost around 500 labor.
I recently had a timing belt go and took out some valves... I needed to get the car running next day so I didnt have time to shop around and bought a newer accord motor for a different gen for $250 at a local yard... Timing belt, wp, etc you are at $500... Not rebuilt but w/e MOST people aren't going to keep theses things for long
To the op... Did you just guess the block is warped? I doubt it is... You can probably get away with a new head gasket and sending the head out to get checked at a machine shop.Last edited by ChIoVnIdCa; 06-23-2010, 09:41 PM.
